2510 Which engine type?
Jeff
07-11-2002 10:14:43
I was going to adjust the valves but I dont know what engine type it is so I can get the right clearance
I have a JD 2510 with engine serial number T24960 and I need to know what the engine type so I can find the right clearance.
john2510-3020
07-12-2002 05:40:09
 Re: 2510 Which engine type? in reply to Jeff, 07-11-2002 10:14:43
IF its a gas then you engine size is 180cid. and the diesel is 202 cid. the valve clearance for gas is: intake valve-0.014 exhaust valve-0.022 in.
diesel: intake-0.014 exhaust-0.018 in.
hope i was of some help. email if you need anyrhing else.
john
John
07-11-2002 18:38:18
Hi:
The diesel engine in the 2510 was the same as a 2020 engine. Hope this helps you :) If not post another followup and I will go look in one of my books and dig up the precise info for you.
John
Ray
07-11-2002 12:02:49
The only difference is gas or diesel,both are
listed in any service manual.
JD70Jim
07-11-2002 14:09:28
 Re: Re: 2510 Which engine type? in reply to Ray, 07-11-2002 12:02:49
He may be trying to use an I&T manual. Those manuals list several types of tractors. His Dubuque Built 2510 engine is a completely different beast than the Waterloo Built 3010/3020 engine. I think the "family" designation for the Dubuque engines is either 300 or 3000 and the Waterloo engines are 400 or 4000.
