Oil pressure quistion reguarding waterloo,iowa expo
Joe
07-15-2002 08:55:31
I just got back from the waterloo expo and it was fun! i liked the way they set things up. I looked at the oil pressure gage at all the b's that were ideling low and there gages red medium-high, same when they reved it up after starting it. when my B is ideling, it reads low, almost none, but when i rev it up, it reads a little above medium. why can there b's stay up and mine goes to almost none?
Clooney
07-15-2002 09:08:35
 Re: Oil pressure quistion reguarding waterloo,iowa expo in reply to Joe, 07-15-2002 08:55:31
Joe, it could anything from worn bearings, to oil that is too thin, to a leak due to a warped oil filter housing at the filter head, to worn oil pump, to other wear or a little of all the above added together. ~You might try an oil change & using 30 or even 40 weight oil [don't use multi-weight like 10W40].
~Your gage could be inaccurate also, so you might try a known good gage.
Joe
07-15-2002 08:56:44
sorry about spelling errors, i can type today!
