Pto pump gear housing
Joe
07-15-2002 18:43:09
I was wondering, do you need a gasket between the pump housing and the cover? 1946 B. they dont sell them i made one for it, could this be why my 3 point dont work?
Deere Puller
07-16-2002 05:48:18
 Re: pto pump gear housing in reply to Joe, 07-15-2002 18:43:09
Light coat of shellac after you clean the mating surfaces w/ Acryliclean or equiv. will seal it up & is recommended by service manuals. No gaskets.
tractorboy
07-15-2002 19:13:22
I hope thats it cuz it wont pump with a gasket in it
Clooney
07-15-2002 18:51:18
Joe, no gasket, that will let the oil by-pass the pump gears cause a loss of pressure.
~It will probably leak a little oil if you don't use some type of sealer on the cover to pump housing. I use Loc-Tite 518 but probably a light coat of any sealer will work [a very light coat on a very clean surface]
