Water pipe on A w/ water pump half closed?
Jerry S
07-16-2002 07:02:51
49A lower water pipe looks like it was cast with half the round end closed off. I know the tractor was converted to have the water pump added later because it ran too hot. I was wondering if anyone knew why the pipe would be that way? The pipe hole has either the lower half or upper half (I cant remember which now) cast closed. Since this pipe probably was changed when the water pump was put on (I believe they have a smaller diameter than the thermosiphon units) why would they close the thing up? Was this a mistake in the casting?
Will P
07-16-2002 07:19:58
 Re: Water pipe on A w/ water pump half closed? in reply to Jerry S, 07-16-2002 07:02:51
I have seen this on this board before. It is to slow the water down so it has time to cool in the radiator. The pump will pump it to fast. A little restriction will slow the water down. Give it time to cool. Don't remove it.
Will P
Jerry S
07-17-2002 07:41:48
 Re: Re: Water pipe on A w/ water pump half closed? in reply to Will P, 07-16-2002 07:19:58
Thanks. Makes sense now.
Will P
07-17-2002 20:23:26
 Re: Re: Re: Water pipe on A w/ water pump half closed? in reply to Jerry S, 07-17-2002 07:41:48
No problem. Some weird things that Deere did. But it works.
Will P
