Clooney axle seals
36 A
07-17-2002 19:22:28
On both my 36 "A"s the rear axle seals are leaking.I was at a small shop in town and he said that they only had the dust felt on the outside is this ture.Need to know what all to get.Also one has 12 spline that should have 10. Dose this mater on the parts and i have a 44 A with 15 spline can i swap the 12 and 15 around.The 15 have 9 bolt hubs and i want to swap the cast off that tractor for pulling.thanks
Scott
07-18-2002 08:58:46
 Re: clooney axle seals in reply to 36 A, 07-17-2002 19:22:28
I just wanted to make a note here for you that when you go to get new seals for your axles, see if you can find a double lipped axle seals. I have a '41 B that I just installed new bearings and seals in. I was going to put what JD called for, but then a mechanic told me to look for double lipped seals and I found some at a bearing company here in Des Moines, Iowa. They just give you two times the sealing surface than a standard single lipped seal does.
Scott.
Des Moines, Iowa
Clooney
07-18-2002 03:48:27
36-A, your 36's have an outer felt DUST/DIRT seal that only keeps the dirt out of the outer bearing. They have inner oil seals [just outside the inner axle bearings] that keeps the oil in.
~You sure asked me a difficult question on that axle swap...Here's what I know on that [not much as I'm not a puller]...There was an axle change from 10 to 12 splines in mid to late 1937, with that axle change the axle bearings were changed. I have installed the 12 spline in the 10 spline axle housings using a mismatch of bearings/races from Deere [sorry I don't have the numbers as I did the change years ago], I believe the seals are different also, so you will have to measure the housing bore & axle O.D. at the seal area & match them up, [or if just re-sealing, use the numbers on the old seals]. ~I don't know what is involved with the 12 to 15 swap as I don't know what rear axle housings you are working with. ~Your question would be a good question for the puller board on YT here. Those guys are always swapping axle housings, axles & hubs.
~Be very careful when removing the outer felt retainers [I usually push them out at the same time as the axles come out by using the inner axle nuts against a steel plate to push the axles out, & lightly tapping around the back of retainers with a block of hard wood]. Those retainers are getting hard to come by..... ....
36 A
07-18-2002 19:52:43
 Re: Re: clooney axle seals in reply to Clooney, 07-18-2002 03:48:27
thanks for the replyes.Ive changed seals on a B befor 39 modle.Not to worried about the axle swap because i can run some spoked wheels anway.The tip about removing the retainer will help,had a bugger of a time on the B.thanks again.
