1951JD B Not running and dont know why
Adam Bailey
07-19-2002 08:07:50
I have a 1951 JD B and its not running it was about 3 weeks ago and i left the gas on buy accident. I blew out the cylenders and put new spark plugs in it and it still wont fire what could be wrong?
Clooney
07-19-2002 08:27:45
 Re: 1951JD B Not running and dont know why in reply to Adam Bailey, 07-19-2002 08:07:50
Adam, it could be almost anything.
~Are you getting gas to & through the carb? [open the carb drain valve on the bottom of the carb & see if you are getting a good flow of fuel, if not find out why].
~Are you getting a nice blue spark that will jump a 1/4" gap? [remove a spark plug & leave it hooked to the plug wire & lay it on the head or block then crank the engine & make sure you are getting a blue spark, if not find out why or post back].
~If both of those things are ok give it a compression test, maybe you washed the cylinder walls of oil & you aren't making any compression, [or add some oil through the spark plug holes to help the rings seal]
