Carb for John Deere 60
Jim Kaufman
10-17-2003 12:27:20
I'm working on a 60 JD that was not running for 5-10 years. Replaced most of electrical system and replaced carb gaskets. Tractor was running for 1 min. at a time. It would run for 45 sec. then under full choke keep going for another 10 - 15 seconds. I replaced the screen by fuel inlet on carb and cleaned screen by sediment bowl. Right now I can't even get it to fire. Fuel is getting to carb, but even under full choke it seems I cant get gas to combustion chamber (plugs stay dry). Any ideas??
R. Marg
10-17-2003 14:09:34
 Re: Carb for John Deere 60 in reply to Jim Kaufman, 10-17-2003 12:27:20
sounds like the main jets are clogged try spraying some gumout carb cleaned in to them and or take it back off and sock it in carb cleaner for a day or 2 you can get a 2.5 galloin of it at the parts store but it is a little priceie or you can buy a new carb for around $400
