John Deere 6 ,12 or 24 volt? Possible of a 70 or 720
Joe
07-24-2002 14:32:51
I got a generator that don't have a tag.How can I tell if it's a 6,12 or 24 volt.It has 3 brushes in it.If thats any help.
DON
07-25-2002 13:41:59
 Re: John Deere 6 ,12 or 24 volt? Possible of a 70 or 720 in reply to Joe, 07-24-2002 14:32:51
If it has 3 brushes it's a 6 volt and probably off of an "A" as the 70 used a 2 brush gen. with regulator 6/12 volt, unless somebody proves me wrong. Don
JOE
07-24-2002 21:48:48
Well! Now I'm really confused.Thank for your help maybe someone else will give it a try.Then I can go for two out of three.
John Ne.
07-24-2002 22:24:13
 Re: Re: John Deere 6 ,12 or 24 volt? Possible of a 70 or 720 in reply to JOE, 07-24-2002 21:48:48
The six volt generators, with the cut out relay, used a 3 brush generator, if you look closely, the third brush can be adjusted, for output like the guy said,,,, twelves had two brushes,,,John in Nebraska
cole in mo.
07-24-2002 20:57:27
I'v got a 46 A that is 6 volt and it has three brushes. the third brush is is for adjusting the output.
twopop
07-24-2002 19:37:38
I think 6 or 12 has 2 or 4 brushes and 3 would be a 24 volt off of a 70 thru 730 or even a 4010 or 20 diesel
RICHARD
07-25-2002 06:35:54
 Re: Re: John Deere 6 ,12 or 24 volt? Possible of a 70 or 720 in reply to twopop, 07-24-2002 19:37:38
A 70 is 12 volt or 6 volt for a diesel
