HELP not so good viberation
36 A
07-28-2002 16:35:38
Took one of my 36 "A"s to a pull. first time on this tractor it was grandpas, pulled 5 classes took 2 3rds,1 2nd.good day had by all.Anyway the tractor has a vibe that shakes the steering wheel bad.The other 36A that ive pulled is as smooth as silk.On a unstyled a the clutch drive cant be off because of the pin in crank.What else is there to look for.
Clooney
07-28-2002 16:53:06
 Re: HELP not so good viberation in reply to 36 A, 07-28-2002 16:35:38
36 A, look for a bent crank,[does either end wobble?]
~Look for the flywheel to be off a spline or two.
~Look for different pistons than it was balanced with when built.
~Look for a replacement flywheel that was changed at one time.
~Look for the WOT RPM to be running too high.
~Look for different connecting rods or unmatched rods.
