2010 Hyd. Pump
Gordon
07-29-2002 11:05:46
Can someone tell me where the Hyd. Pump is located on a 1964 2010 Utility? I was told it was hooked to the front of the crank shaft & was located under the radiator, but all I see up front is the power steering pump. Or is the Hyd. pump part of this? If so what drives the pump? Thanks for your help..... Gordon
Fred in sunny Connecticut
07-29-2002 12:28:59
 Re: 2010 Hyd. Pump in reply to Gordon, 07-29-2002 11:05:46
The pump is in the middle of the tractor. Directly below the center is a cover with 6 or 8 bolts maybe 4,been a while since I had one,sits at a bit of an angle,flat steel take it off and you can see the pump from it. What trouble is it giving you? is there adequate fluid, a new screen,alos makes a world of difference. For Now, Fred
Gordon
07-29-2002 11:43:02
Also is this engine a sleeved engine or not? It's a gas tractor.....Thanks
Steve in Tennessee
07-29-2002 19:34:56
 Re: Re: 2010 Hyd. Pump in reply to Gordon, 07-29-2002 11:43:02
It's an odd setup. The engine has a sleeve plate that contains all 4 cylinders. It drops into the block from above and is sandwiched in by the head.
Th hydraulic pump is located in front of the clutch behind a flat cover under the belly of the tractor. If you remove the bolts from that cover, you can see the pump.
