#5 mower, removing key
Farmer Jack
07-30-2002 05:16:02
What are some good methods to use in removing the key which retains the pitman flywheel to the drive shaft?
THanks,
Craig
07-30-2002 19:33:52
 Re: #5 mower, removing key in reply to Farmer Jack, 07-30-2002 05:16:02
The key is tapered and driven in.
We've discussed this in the past on this board many times before.
My suggestion is to pull out the key and then the flywheel should slide right off. Drill and tap the key, then use some sort of slide hammer arrangement to pull the key out. This should work well if everything is not rusted solid.
After I took my #5 apart the hard why, then I discovered the tapered key. The key is the only thing that holds the flywheel on.
Otherwise the puller idea may work if the key comes with the flywheel.
Sam Vastano
07-30-2002 07:08:37
Farmer Jack,
This might not be the proper way but I just used a wheel puller to get the flywheel off the shaft. the key came with it and then I took the key out of the flywheel. I had to use heat and a big wheel puller but it worked.
Hope this helps
Sam
