Wtw baering noise
36 A
08-14-2002 20:01:07
WTW i have an 44 A and a 39 B both have this rough bearing noise but they both seem to run good.the noise seems to come from the govner . but noise can travle.any ideas , do you think it could be that cam bearing you referd to on a nother post. thanks
WTW
08-15-2002 07:54:18
 Re: wtw baering noise in reply to 36 A, 08-14-2002 20:01:07
36, If your tractor is running OK good chance your noise is governor bearing related. For sure on your "B" as the cam on all "B's" do not use a bearing per say, the cast iron cap is the bearing on all "B's". On both the "A" and the "B" the governor and fan bearing are the same bearing / part number. They do fail and are a very common over looked area when people restore these tractors. The bearing have a pretty tough life especially the governor bearings because the governor located on top of the engine gets all the moisture and condensation that the engine produces, kind of like a big steam dome setting on top of a boiler. This moisture and condition does play havoc with the governor bearing. I would start at the governor if I was you. Good Luck, Dave W.
