620 Carb bowl leaking
John VB
08-20-2002 18:45:48
The carb bowl is leaking around the retaining nut on my 620. The parts manual shows two small gaskets (part #10088) are required. They are a hard fibrous type. Where do the two gaskets go? Both inside the bowl or one in and one out. The diagram in the parts manual just shows one gasket. Thanks.
John VB
Mark
08-21-2002 14:05:13
 Re: 620 Carb bowl leaking in reply to John VB, 08-20-2002 18:45:48
There is also an o-ring type seal on the adjusting needle in the middle of that bolt that will leak also.
ChuckW
08-20-2002 20:43:16
you can put one inside and one outside...I always tap the inside of the bowl downward to get a tighter fit to the large gasket. Also some indian head type gasket solution works good on the lower to prevent leakage. Don't use too much.
