2010 tune-up help
Jeff Hoffman
08-22-2002 10:43:24
I just tuned-up the 2010 last week after it started spitting and sputtering. I replaced the plugs, wires, cap, rotor, points and condensor.
Life was good for a few hours but then the miss started again. I pulled the plugs to see if I had fouled one and they all appeared wet. Next I pulled the cap and rotor and found that the contacts in the cap had a white powder build-up.
What's going on, the points gap seem correct, I checked the ballast resistor and that seems fine. Could incorrect timing cause this. I want to solve to problem before I smoke some more perfectly good parts.
Any ideas?
Steve - IN
08-22-2002 19:51:13
 Re: 2010 tune-up help in reply to Jeff Hoffman, 08-22-2002 10:43:24
Jeff,
Sorry, got in a hurry and forgot to say -- Yes, you could be right about timing. Pull the distributor and set the engine at TDC. Then reinstall so you're sure the rotor is lined up with the contacts inside the cap when the coil fires.
Steve
Steve - IN
08-22-2002 19:16:32
Jeff,
I'd first suspect the condensor. If you have a multimeter that does capacitance, the condensor should measure about .25µF (micro Farads). If you pull the distributor and measure the resistance while turning the shaft slowly, you should see 0 to some megaohms. If you see a 0 to very little resistance change, it's the condensor.
If you have no meter handy -- but do have some old 12V light bulbs, here's a kind of fun, but more time consuming, way to troubleshoot:
Run wires to two test lights from the + and - terminals of the coil. (I'm assuming the 2010 as Newgen is neg ground. If not, think backwards) When the engine is running, the light on the + side will be steady, and the - side will be dim or flickering.
When the ignition cuts out, see which light goes out.
If it's the flickering light, check for shorts in the distributor, shorts in the wire from the coil, points not opening, or bad condenser.
If the steady light goes out (+ terminal) Look for shorts -- melted or worn insulation on the pos wire. Also, ballast resistor may be bad or it could also be a bad ignition switch.
If you don't want to go to all that trouble, some guys say that spraying contact cleaner on thin cardboard -- like the cover on a book of matches -- then swabing that through the points' contacts a few times will keep them running for months without an ignition miss.
good luck with it...
Steve
