Decals for JD 3010
John Revels
08-24-2002 21:02:54
Does anyone know where I can get a complete decal set for my JD 3010 gas tractor?
JD70Jim
08-25-2002 15:34:39
 Re: Re: Decals for JD 3010 in reply to Steve - IN , 08-25-2002 00:36:46
If you buy a set of decals for a 3010, make sure that the JD "oval" for the back of the upper seat cushion bolster is the FOUR LEGGED running deer and not the post 1968 TWO legged replacement, be sure that the 12v decal for the electric outlet is encluded, that it has the clutch adjustment instructions decal for the area just above the foot clutch on the side of the tractor. The "3010" side panel decals will likely be correct in every case. You will also want a black and silver "warning" decal for the lower dash. There should also be the correct "Donaldson air cleaner" instruction decal. Most of the cheaper sets have PLENTY of assorted decals which I presume you would stick on the fenders etc, including one which indicates that there is a "fast slow" hydrsaulic adjusment for the scvs, but the units which use THOSE first showed up in 1969 on the "console" tractors. Also, be sure that the gear shift indicator decal for a 3010 has that 3rd reverse gear in the 4/7 range. If it doesn't, remember your 3010 DOES have 3 reverse speeds.
Kent Kaster, @K&K tractor parts has correct sets. Do a "search" and you will get the correct address.
