G-MAN
08-29-2002 05:39:44
Re: Re: Re: Re: Re: camshafts for 47 JD A in reply to Jim, 08-28-2002 19:44:41
As far as the air cleaner goes, I believe I'm going to run the stock oil-bath on my tractor. From the majority of what I've read on this site, it takes a very big paper element to flow enough air for a "G" - especially if the aif filter is mounted right on the carb, as you so often see. Those engines take a lot of air very quickly, as both cylinders are filling 180 degrees apart. The other things I'm doing to my '48 "G" are: .125 over Arias pistons with higher compression, offset-ground crank running "A" rods, Robert's carb - my tractor didn't have the 51 on it, so I'm going to have him modify the gas "A" carb that was, gas manifold, electronic ignition, camshaft and lifters redone, hardened seats and probably new valve guides and/or valves, and maybe a little head work - port matching and just smooothing the ports as G Taylor mentioned. I might shave the block some, but I'm not going to get too carried away on compression, as the tractor will probably see more play time than pulling time. I'm also planning on installing a Crum 3 inch exhaust pipe and stacks. Nothing real fancy overall, but I'd like to get in the neighborhood of 60-65 hp out of it. Hopefully, with access to a dyno and some tweaking, I can get it. The project is taking longer than I planned, but I'm finally getting the basic tractor together and I should be starting on the engine work soon.
