1947 john deere b needs more power in tractor pulls
ryan
08-28-2002 17:40:06
how do i get more power for 1st or 2nd gear when pulling in the tractor pulls
Terry H
09-03-2002 13:55:52
 Re: 1947 john deere b needs more power in tractor pulls in reply to ryan, 08-28-2002 17:40:06
ryan,
I'm with G-MAN and phil. My stock '47 B has never run out of power before running out of traction. Start off with what G-MAN suggests, then explore more exotic options.
Good luck,
Terry H
G-MAN
08-29-2002 10:58:50
Ryan, sometimes the simplest things are the best. Get a hold of a service manual and start with a good tuneup. Check compression and make sure it is up to specs. Adjust points, timing, and valve lash. Install new plugs, wires, cap and rotor. Properly adjust the carb and governor. Make sure your air cleaner is clean and not plugged up with old grease. Make sure the strainer in the sediment bowl is good and clean, as well as the strainer at the carburetor. Make sure your fuel tank and lines are in good shape and not filled up with garbage. If you get all of things squared away first, it will provide a good baseline for judging the effectiveness of future modifications. I agree with Phil, your "B" should be able to spin the tires in low gear bone stock.
phil
08-29-2002 10:33:37
Does your 1947 have a 'creeper' first gear? If not, it may be a 1946 or older. But if you do have the 1.5 mph first gear, you won't run out of power, a late-model B with a stock engine will always spin-out, even at half throttle.
