1952 john deere A main bearings
john graves
08-29-2002 11:12:48
we are now restoring a 1952A, one of last 600 built. problem is main bearings, yes i understand the type, pressed in and pinned, and they have to be fitted after inatalled in caps, the problem is the availiblty of new bearings, local jon deere dealer contacted corp. john deere parts dept, no one understands what these bearings are, so we cant find replacement bearings. will JD 60 bearings fit or does anyone know of a supplier of these ,any suggestion would be appreciated.
J Boyce
09-16-2002 20:20:16
 Re: 1952 john deere A main bearings in reply to john graves, 08-29-2002 11:12:48
John, I am going through the same situation as you. I am installing new main bearing housongs with the sleeve type bearings in a 1951 A. I am not sure what the problem is with the dealer on your end, but I am a mechanic at a Deere dealer and I ordered these bearings right there at our parts counter! The correct part number is A4394R. The cost was approximatley 75.00 per side. If you still can not get them, contact me and I will be happy to get them for you. Provide .004-.006
judy
09-01-2002 18:40:45
we have a jd 2010 that the main bearings are bad in we were trying to take the crank out so we could have it turned and we can't get the tractor to come apart so we can get the crank out could you tell us what we need to do to get it out. and well it do any good to have the crank turned thanks for any help.
lynn
08-29-2002 17:17:37
john..if you can find some older main bearing housings..the ones with the adjustable bearings john deere had these bearings a few years ago..lynn
SEAMO
08-29-2002 12:23:10
I would check with Tom Underwood he had some new old stock at the Portland Show. His Phone is 785-749-5231. They are high alloy aluminum they could be made.Let us know. Earl In Illinois
