Driving disk stupid question
Jerry S
08-30-2002 09:14:35
I think I know the answer to this but want to make sure. I took everything off the right side of the A to change out the camshaft and noticed the clutch driving disk has a little hairline crack across the part where the fiber disk contacts it. The disk otherwise is in great shape. This tractor is going to just be a play toy. Will this disk be ok to use? Can it be welded adequately? Thanks for your help.
ChuckW
08-30-2002 10:03:36
 Re: Driving disk stupid question in reply to Jerry S, 08-30-2002 09:14:35
your problem with a damaged disc is saftey. If it should break and wedge it will take you out of control....why not be safe, spend a few bucks and replace....
Jim
08-30-2002 12:23:53
 Re: Re: Driving disk stupid question in reply to ChuckW, 08-30-2002 10:03:36
Jerry S ---- ChuckW is right on ,if it brakes you won't be able to stop,aslo it will damage the splines on the cranckshaft.-save time and money and get another drive disc,saftey first of course!!!.
