111 engine trouble
geoff
08-30-2002 21:27:32
i have an 11hp briggs out of a 111 that i am using on what i like to call a super tractor, and the thing is, the engine starts fine, runs for 20 min surges then stops, followed by gas pouring out of the carb, and now it will only run for about two minutes then quit, i rebuilt the bowl area of the carb but yet it still leaks and quits, the gas pours out of the carb at the same rate that the fuel comes out of the fuel line.
leon
08-31-2002 03:50:03
 Re: 111 engine trouble in reply to geoff, 08-30-2002 21:27:32
I think there is a float in that carburetor. I have a JD 111 bought new some 20 or 25 years ago and have nver had that problem. Assuming there is a float, it sure soulds like the needle valve actuated by the float in the carburetor is not closing for some reason, maybe the float is sticking down or the float isn't floating!
