1949 J D model B
Rich Morris
09-02-2002 21:10:34
Hi! I just picked up a J D model B today. How do you check the engine oil? What weight oil do I use in it. How do you check the trans oil & also what weight. Thank You! Rich
Brian
09-04-2002 05:16:08
 Re: 1949 J D model B in reply to Rich Morris, 09-02-2002 21:10:34
You check the oil by opening the drain on the side of the block behind the flywheel. The oil should just drip out of the drain. Use 30 weight oil.
You can still buy the maintenance, parts, and operators manuals from JD. I would recomend doing so. They have really helped me.
Good Luck
