1936 A Right side spark plug not firing some times
Ben.So.Tex
09-05-2002 08:07:37
My 36 A I just got it running after setting for 25+ yrs, It has been running fine, I plowed the garden with it, no problem, Now when I start it it not firing on the right plug all the time,( it dose seem to fire a slow idel)( mainly cutting out at higher rpm) I put new Plugs,New points,I have not change out the cap or roter yet. Help me if you can, Thanks BEN
Lyle Pfeifer
09-05-2002 22:41:17
 Re: 1936 A Right side spark plug not firing some times in reply to Ben.So.Tex, 09-05-2002 08:07:37
Ben, check the inside of your cap for excess carbon buildup. Also, check that the tip of the rotor is clean and not carboned up. A lite cleaning with 400 grit sand paper, very carefully, should do the job. Lyle
Will P
09-05-2002 20:25:12
Ben, are you running solid core wires? Don't use carbon core wires with a mag. That is what I have been told. As for plugs. Lots of people don't like Champions. Me included. I run Autolite. Champions would foul out in about 2 months. I have had my Autolites in for almost 2 years. I have a early styled B. Your unstyled will take different plugs. Can't help with the number. Good luck.
Will P
Don
09-05-2002 14:00:16
I have had the same problem with Champion plugs. After only a short time, in running, the right plug started missing. I went to another brand and haven't had any problems, since.
Jim
09-05-2002 09:03:48
Ben----- Check the steal tube the spark plug wires go through,sounds like you have a bad spark plug wire and it is arcing inside the tube,if you have another wire, run it outside the tube and see if the skip goes away.--Pull the mag cap,check for cracks,or may have cracked the spark plug on insatllation? good luck.
