2 cylinder on coke bottles
Eshler
09-05-2002 09:07:00
I've heard about this and saw it last year at the Expo in Michigan. Does anyone have an idea on how they do this? Do they put it up on bottle jacks, lock the clutch in and then let it down on the bottles? I'd think you would really want to loosen the clutch up, just enough to get the wheels turning.
dan_41jdh
09-05-2002 15:58:57
 Re: 2 cylinder on coke bottles in reply to Eshler, 09-05-2002 09:07:00
Gene Tencza's website has a segment about a fellow who did this to his "H"...
Brandon
09-05-2002 14:32:38
third party image
There was an A on Coke bottles at the 2002 Springfield, Ohio Expo. Engine was running, and the wheels were turning. See the attached picture-it was neat!
I don't know how they got it on there. Makes you wonder!
Notice that it is roped off. You might not be able to see it, but they also had a rope on the clutch lever staked to the ground...if it fell off the bottles, the rope would pull the clutch, and the tractor would stop. Hopefully...
Brandon
Don
09-05-2002 13:56:53
It is my understanding that John Deere was the only manufacturer whose tractors would work with this demonstration. Other manufacturers tried and were unable to get their tractors to stay on coke bottles, when running.
Steven@nd
09-05-2002 13:09:08
I have seen it in person with a Spoker D. Don't remember exactly where, but it was impressive!
Steven
Bill {Antique Acres}
09-05-2002 12:45:43
Their was a gentleman at Portland this year that had a JD running on Coke bottles, I too have heard of it and saw pictures, but I had never seen it in person until 3 weeks ago. It was very impressive.
Putt Putt
09-05-2002 12:01:59
You were seeing a bit of history, there. John Deere used to use this very demonstration to show Mr. Farmer that, although 2 cyl, John Deere tractors were smooth enough to be balanced on Coke bottles. I believe this was circa late thirties
Ben.So.Tex
09-05-2002 09:35:47
I have seen it some place on the web site where their is, or was, a tractor setting on coke bottles with the engine and wheeles turning,It could of been in the green mag, or the two cly mag too. Hard to remember when you get this C.R.S. Good Luck BEN,,
mike
09-10-2002 20:21:45
 Re: Re: 2 cylinder on coke bottles in reply to Ben.So.Tex, 09-05-2002 09:35:47
My father worked at jd dealerships and I had heard him talk about setting tractors up to run on coke bottles ,just never thought i'd ever here about it again
