1953 model 40
Matt Benedum
09-08-2002 17:25:26
Just curious how a Model 40's cooling system works, since it doesnt have a water pump but requires antifreeze. How does the water cool the engine if it doesnt circulate. Thanks for the info, I'm new to restoring this good'ole machine.
Matt
Clooney
09-08-2002 17:48:54
 Re: 1953 model 40 in reply to Matt Benedum, 09-08-2002 17:25:26
Matt, the water does circulate. Tractors with Thermo-Siphon cooling circulate the coolant by convection flow...Convection flow works by the water in the engine block absorbing the combustion heat & rising in temperature, as coolant temperature elevates it flows upward & enters the radiator through the upper radiator hose, as the coolant is cooled by the radiator/fan it falls & re-enters the engine at the lower radiator hose to complete the cycle over again. [the principle is: hot water rises & cool water descends, thereby creating a flow]
