Axle leak after all new seals on B
Joe
09-08-2002 18:24:28
WHY??? i put in the new oil seal with the lip towards the inside, the new felt, and it leaks tranny oil ever since about 2 months ago when i rebuilt it. my tranny isnt over full, why would this leak after new seals??? it fit tight and went together correctly. THAT WAS A LOT OF WORK FOR NOTHING. any ideas?
bob
09-09-2002 10:49:47
 Re: Axle leak after all new seals on B in reply to Joe, 09-08-2002 18:24:28
mabey you riped the new seals when you were putting them on. did you clean the axle shaft first?
Deere Puller
09-09-2002 09:43:01
Many times the axles are worn in the seal area, requiring a handi-sleeve to seal properly. This happens quite a bit on high-use / high stress seals. Harmonic balancers on SB Chevy engines are also notorious for this problem. I believe that National has a sleeve that will fit your axle, tightening things up considerably. Also, as Clooney has already suggested, be certain to clear the axle flutes of oil during the process. You may try to put some petroleum coloring in the gear lube to see whether it is old or new oil leaching out..... .
Clooney
09-08-2002 18:42:05
Joe, it could be anything from a worn spot on the axle shaft, to loose bearings, to a seal that was cut or dislodged when the axle was installed, to missing oil seal washers.
~Did you remove the old oil from the axle tubes? Maybe it is still old oil leaking out of the outer axle tubes. Does the oil that is leaking out look new or old & black.....
