100HP
Bill
09-14-2002 18:45:41
What was the first John Deere over 100HP?
gene
09-18-2002 06:48:01
 Re: 100HP in reply to Bill, 09-14-2002 18:45:41
i called my father an he said it was the 1959 john deere day north of marshalltown ia when they were really putting a show a introducing the 30 series tractors, but they also brought out the 8010 it had a fully mounted 10 bottom plow on it so it was the 8010 in 1959 was the first over a hundred they were right an i was wrong
G-MAN
09-16-2002 10:47:50
The 5010 was the first John Deere row-crop tractor to exceed 100 hp - and did so on both the drawbar and PTO - a first for the entire industry. The 8010/8020 is a four wheel drive tractor and was powered by a Detroit 2 cycle diesel. The 5010 used the 531 cubic inch Deere engine. So if you mean the first Deere tractor with 100 hp, the 8010 gets it. If you consider it the first "completely" Deere tractor - it's the 5010. The 8010/8020 tractors (all 8010s were recalled and rebuilt as 8020s except one) are rare enough that a lot of people haven't even heard of them or seen a picture of one.
G-MAN
09-16-2002 10:51:19
 Re: Re: 100HP in reply to G-MAN, 09-16-2002 10:47:50
I screwed up - the 5010 wasn't actually a row-crop tractor, as it didn't have an adjustable tread front axle. I should have said two wheel drive rather than row-crop.
Bill
09-15-2002 13:57:50
Now I am confused. Was the 5010 or the 8010 the first John Deere over 100 HP.
BMAN
09-15-2002 15:41:17
 Re: Re: 100HP in reply to Bill, 09-15-2002 13:57:50
It was the 8010. It came out two years before the 5010.
50jd
09-14-2002 21:37:22
the 1959 8010
The 5010 of the New Generation
09-14-2002 20:04:44
Would easily pull six bottoms.
cannonball
09-14-2002 18:49:43
i would say from factory spec the 5010..
cannonball
09-15-2002 14:10:02
 Re: Re: 100HP in reply to cannonball, 09-14-2002 18:49:43
i believe that the 8010 is right 1960-1961 had 6 cyl..gm motor.....4 wheel drive
