Re: 47A ignition timing-
rollo
09-26-2002 16:03:40
for what it's worth, I set my timing to the JD specs. The timing is selected to avoid valve damage when the tractor is working, not idling. If you run the timing too far advanced under a load, you'll literally break the valves; too far advanced at idle only burns them up gradually.
