Help power lift on 39 B????
36 A
09-29-2002 10:34:53
Just installed a power lift on my 39 B it came off a non running tractor.The little tag on top has PL-B108985.The plate that spaces the gears out is cracked and ill have to take the top part off because of the drin.what will i have to contend with ,or is it pretty straight foward.It did lift but would not go down.
Jerry S
10-03-2002 13:20:26
 Re: Help power lift on 39 B???? in reply to 36 A, 09-29-2002 10:34:53
Since nobody answered, I will try. The valve body on a power lift is real simple to take off and not much to surprise you. Remove all 6 or 7 bolts (1 is a nut) and it slides right backwards. I'd buy a new gasket for it if yours is old. Probably also a good time for one of those I& T manuals or a B shop manual from Deere if you don't have one. Makes things lots more sensible with the pictures than what I could describe here.
