I short the points to ground on a wico mag, broke mag?
jim smith Ft wa
09-29-2002 11:27:33
Hi
I ran a wire out of the wico mag to stop it(tractor) ran good until I used my new ground wire 1 time, can't get it to fire consistantly since I grounded the points, Did I kill, my mag?
Any Ideas?
JIm
Clooney
09-29-2002 15:26:41
 Re: I short the points to ground on a wico mag, broke mag? in reply to jim smith Ft wayne, 09-29-2002 11:27:33
Jim, I doubt you hurt the mag, there isn't much in there that can be hurt with a ground wire. ~What model Wico mag & exactly where did you hook the ground wire?
~Try removing the wire & see if it gets better, maybe the wire is shorting out or has pulled loose..
Jim Smith ft wayne
09-29-2002 19:30:30
 Re: Re: I short the points to ground on a wico mag, broke mag? in reply to Clooney, 09-29-2002 15:26:41
its a wico model X
I have a white spark, not blue. its back fireing
now, will not run, was running good
