1939 john deere b froze up?
Rich hvfd
10-05-2002 17:17:59
i just bought a 1939 jd model b its froze up tight, the valves are now free but its still very tight, anybody have any tricks or tips? its now soaking in oil will this eventually do the trick? i gave $200.00 knowing it was froze but the tires are great and the metal is all in real good shape. thanks for any help Rich
Paul from MI
10-05-2002 18:57:07
 Re: 1939 john deere b froze up? in reply to Rich hvfd, 10-05-2002 17:17:59
Rich,
Serial number sounds right to me. If you got the valves free you already avoided on of the things guys forget. You don't only worry about pistons when you are working on a stuck engine. Really safe way to get it apart is to remove pistons, rods, and cylinder as a unit. Then try penetrating oil, hydraulic press, hot whatever & you won't damage anything thats not already questionable. Penetrating oil and time will do good things. If not, them move to more drastic measures like filling cylinders with kero and burning it off, etc.
Paul
Paul from MI
10-05-2002 18:50:25
Rich,
Paul
Rich hvfd
10-05-2002 17:22:00
we also tried dragging it with no success.. also the serial number is 60053 can anyone tell me more about this were thinking this is the 53rd of the styles made? thanks again, Rich
Ben.So.Tex
10-06-2002 10:33:23
 Re: Re: 1939 john deere b froze up? in reply to Rich hvfd, 10-05-2002 17:22:00
Don't drag it you could bend a rod..I picked up a 36A in july with a stuck engine.. I used brake fluid in the spark plug hole and down the exhaust pipe..I put a pipe on the fly wheel and it came free with the first yank.(maybe I was just luckey.).. I broke a froze 60 with oil.. my two cents
37G
10-05-2002 18:49:50
actually it would be the 54th styled B built if it is serial number 60053 because they started at 60000. They are a very few slight differences on the very early one. i had the 6004X don't remember last number but no longer have it move to bigger and better things (unstyled G's) Have fun with it i still have a 39 with factory flats and it is truely beautiful now that it is completely restored
