John Deere 301
Jeff
10-06-2002 09:14:14
Can a loader be attached to a JD 301 easily? What changes are needed?
cannonball
10-07-2002 10:09:18
 Re: John Deere 301 in reply to Jeff, 10-06-2002 09:14:14
should be able to tap into the hyd line by putting a tee right where your remote line hooks up and put the return in filter cover ..if it is not tapped you can get one that is from jd..have nice day may god bless
Big Dog
10-06-2002 14:39:23
You should have no problem with a high lift for your 301.I have one and it has a 145 JD high lift on it. All that was needed was the mounting brackets that bolt on to the sides and the fluid system was tapped into down under the tractor by the hydrolic filter. There is a factory add-on block - manifold down there where someone put two pioneer couplers. I suppose you could just run long hoses back to your remotes. You wouldn't know where I could get a hood do you? My 301A is a bit of a cosmetic nightmare.
