1941 john deere b
jim
12-25-2003 16:07:22
what is the max a block #B1783R can be bored out? with out installing sleeves and not be to thin?
Dave
12-25-2003 16:26:11
 Re: 1941 john deere b in reply to jim, 12-25-2003 16:07:22
Jim,
I work on JD tractors in my shop and have for many years. I have seen A's and b's bored out to .125 and seem to hold up just fine. My 1946 JD A is at .125 and I pull with it and plow many acers in the spring. My personal opinion is if you can clean your bore up at .090 Id stay at that. The only reason I went to .125 is my A is running 54 horsepower at stock rpm's. The next overhaul it will need sleeves. Hope this helps.
Dave
