Sediment Bulb on '48 A
Jericho
10-20-2002 08:43:07
The sediment bulb on my 1948 A is full of thick, nasty gas. I was planning on just taking it off, cleaning it real good, and putting it back on. However, a friend recomended buying a sediment bulb for a 730 and using that instead of the original one. He said that the original one has some kind of Low-Oil-Pressure sensor that tends to malfunction quite often, and that I'd be better off using a 730 bulb. Does this sound right to you all? Not that I don't trust his opinion, but I like double checking things like this before I do them. THanks guys.
J
Dae K (Fl)
10-21-2002 14:12:43
 Re: Sediment Bulb on '48 A in reply to Jericho, 10-20-2002 08:43:07
My 1948 A just has the standard sediment bowl on it, always been that way.You do need to change that screen sometmes. NAPA has the bowls and screens. The only thing to watch for when installing a different type fuel filter, such as an in-line filter is they have to be for a gravity feed system. A lot of the newer filters are used with pressurized fuel systems and the flow rate will be to slow or not at all on a gravity system.
dave
F-I-T
10-20-2002 09:04:46
Jericho:
I used to have a '48 A, and it did not have the oil pressure sensor fuel shut-off in the sediment bowl. I don't think that came out until the model 50-60-70 gassers.
The sediment bowl called for your "A" is the same as used on my 70 Diesel, AA 4331 R. That one is a pretty common unit, and most dealers have them in stock (they were used on combines, haybines, etc, too).
You can probably do a good job of cleaning yours with some lacquer thinner, MEK, and elbow grease. Be sure that little screen is in the top of the sediment bowl and that it's in good shape. It might save you a trip with the carb to the workbench.
Frank-in-Tallahassee
70D // 855
BUDD
10-21-2002 16:04:52
 Re: Re: Sediment Bulb on '48 A in reply to F-I-T, 10-20-2002 09:04:46
FIT; I can not believe this. I have been reading your post for over a year and you have always been on top of things (GOOD JOB BY THE WAY), until now that is. The fuel shut off that you are refering to is Part# AA 5775 R it was avalible on ser# 584000 I think that would be 1949. I have one of these on my 49 A and I love it. It does need to be gone though, but I do think I will keep it as of now that is.
BUDD
F-I-T
10-21-2002 19:30:53
 Re: Re: Re: Sediment Bulb on '48 A in reply to BUDD, 10-21-2002 16:04:52
Budd:
I'm a little confused. I got that off of my Parts CD, and thought it was for the 584000 and up. I'm on the road now, and don't have the CD here, but I know our "A" (595751) came with a straight sediment bowl, and no oil pressure switch. I was always told that it was a '48 at that serial number. I later had a '49 (serial was around 610,000 maybe ?) and it had a straight through bowl, too.
Are you saying that the '48's and up had oil pressure switches from the factory, or was it an option ? I don't want to give out bad information. I wouldn't doubt that there were alot of things like that adopted to the 680,000's and up. That's when they were starting to leak out improvements that they were going to feature on the numbered series.
I'll check my CD more closely when I get home on Friday, but I'd appreciate a re-check on those numbers.
Frank-in-Indianapolis
BUDD
10-22-2002 03:51:59
 Re: Re: Re: Re: Sediment Bulb on '48 A in reply to F-I-T, 10-21-2002 19:30:53
FIT;
First let me say that if I ofended you I did not mean to. Seocnd my post was intended to have a little of humor in it. Third I rank you with Clooney as far as good helpful post. Acording to my parts book Automatic shut off was # AA5775 R for 584000 and later. I would asume that this was an option as there were at least two other shut offs offered. All fuel - AA 499 R up to 697756 and AA 5334 R 697757 and up. Also my book shows AA 4331 R for 662729 and up. This book is a little confusing to me, I think I am reading it rite. I looked at a ser. # list and the way I read it 1948 started with 594433 and went to 620842 so I was wrong there I think. I am just getting into the 2 cyd. thing so bear with me. I plan on using all your help this winter when I tear my 49 A apart to see how it works. THANKS BUDD
F-I-T
10-22-2002 06:24:04
 Re: Re: Re: Re: Re: Sediment Bulb on '48 A in reply to BUDD, 10-22-2002 03:51:59
Budd:
Oh no offense. It's just that I was pretty sure that while the oil-pressure shut-off assembly might have available as a field retro-fit, I've seen so many that came with the old straight through sediment bowl that I think that's the way most users had them configured.
I'll check that CD when I get home this weekend because I would like to know how to interpret the book, too.
Good luck on that "A" ! I've done several over the years. They're a nice tractor.
Frank-in-Indy
Clooney
10-22-2002 15:37:15
 Re: Re: Re: Re: Re: Re: Sediment Bulb on '48 A in reply to F-I-T, 10-22-2002 06:24:04
Frank, the parts CD shows that auto fuel shut-off as an attachment & was used from 584000 up on the A. I think it was a retro-fit but can't be 100% sure as I have seen so many with it.
~The problem with the parts CD is it shows parts & usage from the latest parts book that was available at the time of data transfer to digital. There were a lot of parts that were offered as a retro-fit or running improvement that are shown in the later parts book as original [no sub to/from shown]. To determine if a part is original you really need an old original parts book from the era of manufacture & even then if the later replacement part retained the same P/N & casting number the book will list correctly but the part may be slightly different than original. Running changes are not usually shown either if the same part/casting number is used & the later part will fit all. As an example the flywheel was changed on the H at around S/N 10000 but the parts CD shows the later flywheel as used all the way back to the first one. The later is a proper replacement but easy to spot as wrong if familiar with the size difference. The same with the H muffler, it had a height change at around 10000 but the parts CD shows only the later higher muffler used all the way back to 1000. Using the parts CD to do an original restoration can get you some wrong parts installed if "original " is what you are after.
jimbob
10-21-2002 16:56:36
serial number 611909 makes mine a 1948. sorry Budd. No offense
BUDD
10-22-2002 03:54:43
 Re: Re: Re: Re: Sediment Bulb on '48 A in reply to jimbob, 10-21-2002 16:56:36
Your rite 49 started at 620843. No offence taken thanks for clearing that up.
THANKS BUDD
