1010 Wheel Tractor steering problem
Jon with an M
10-29-2002 12:28:34
I have a 63' 1010 Wheel Tractor Loader/Backhoe with the Wide Fixed front end. I am having problems finding parts for the hydraulic steering pistons located under the front axle. They need to be rebuilt or replaced. Any Ideas? I did place an ad in the classifieds and have been looking around the bone yards. There don't seem to be many of these around.
Jon
Henry J
10-30-2002 05:29:12
 Re: 1010 Wheel Tractor steering problem in reply to Jon with an M, 10-29-2002 12:28:34
Jon
You didn't say that you tried JD for the parts. I have gotten cylinder overhaul kits from them for older equipment than you have. If you go with Polk, you may want to consider checking his price against the JD dealer. Sometimes JD can be noticeably more economical than aftermarket. Just my thoughts on a cold rainy morning.
Jon with an M
10-30-2002 08:35:13
 Re: Re: 1010 Wheel Tractor steering problem in reply to Henry J, 10-30-2002 05:29:12
I should have said that. The dealer nolonger sells the parts or rebuild kits.
I'm going to try a local hydraulic shop.
Loren
10-29-2002 13:39:51
When I was looking for 1010 brake parts, Dennis Polk's people told me he has "several" sitting on his lot. You might contact him about your needs, but get your quarters out. He likes his parts a lot.
Jon with an M
10-30-2002 04:58:29
 Re: Re: 1010 Wheel Tractor steering problem in reply to Loren, 10-29-2002 13:39:51
I'll give him a try. Thank You.
