1929 GP front axel loose
marty Z
10-31-2002 10:59:41
I have 2 1929 GP's with the same problem. My parts manual has not arrived yet so I will do my best to describe the parts. The verticle spindles that go through the cast iron yoke are very loose, and sloppy. The collar around those spindles that is part of the cast iron yoke is cracked away around the bottom on both axels on both tractors. This must be a common problem and how have you fixed them? I hope to have the shafts pressed out by this week end so I can better see how bad the damage is .
Thanks
Marty Z
