2020 3 point down pressure?
2020 in mn
11-06-2002 22:02:26
Does or should the 2020 john deere 3 point have both lift and down pressure? Or do the 3 point arms float upward with any amount of upward motion? I know there are different settings for the rockshafts designated by "L", "D" and "LD". If down pressure is available, where should the setting be at? Thanks for your comments and help.
Jim B
11-07-2002 04:37:06
 Re: 2020 3 point down pressure? in reply to 2020 in mn, 11-06-2002 22:02:26
2020 tractors don't have down pressure at any setting.L is load setting,hyd,s are supposed to automatically adjust depth to compesate for load if adjusted properly.D locks out sensing this is best setting for blade and mower work.L/D is a less sensitive setting between L and D.Jim B
