1520 Drowned
Bryant
11-08-2002 19:18:23
My 1520 was partially submerged during recent flooding. I'm not sure exactly how high the water got or how long it stayed under, but it doesn't appear to have risen much higher than the top of the transmission.
There's definitely water in the crankcase and transmission. Any recommendations on other things to do/check/change?
Thanks in advance for your help.
Bryant
G-MAN
11-09-2002 09:19:24
 Re: 1520 Drowned in reply to Bryant, 11-08-2002 19:18:23
Here you go, right from Mother Deere. Instructions and recommendations on putting submerged tractors back into service. It pretty much applies to every tractor Deere has built from the New Generation on up:
PROBLEM: WATER DAMAGE CAUSING RUST AND DIRT OR SILT CONTAMINATION.
SOLUTION: THE PROCEDURES LISTED BELOW SHOULD BE CONSIDERED WHERE POSSIBLE.
1. DO NOT ATTEMPT TO START TRACTOR AS WATER IN THE CYLINDER(S) WILL
CAUSE HYDRAULIC LOCK WHICH MAY RESULT IN MAJOR ENGINE DAMAGE. ALSO,
CONTAMINATED OIL WILL BE CIRCULATED THROUGHOUT THE HYDRAULIC AND
TRANSMISSION SYSTEMS. IF THE TRACTOR MUST BE MOVED TO PERFORM A
CLEANUP, PLACE THE TRANSMISSION IN TOW AND HAUL BY TRUCK.
2. THE ENGINE SHOULD BE COMPLETELY DISASSEMBLED, INSPECTED FOR DAMAGE
AND THOROUGHLY CLEANED. TRACTOR WORKS SERVICE INFORMATION BULLETIN
R79-20-11 SHOULD BE REFERENCED FOR CLEANING PROCEDURES. OIL COOLERS,
INTERCOOLERS, ROCKER ARMS AND SHAFTS, TURBO CHARGERS AND INJECTION
PUMPS ARE ASSEMBLIES ON WHICH ADDITIONAL CLEANING EFFORTS NEED TO BE
APPLIED IN ORDER TO ASSURE FUTURE RELIABILITY. ANY PARTS WHICH
EXHIBIT RUST MUST BE REPLACED. ALL SEALS, GASKETS, ETC., MUST BE
REPLACED.
3. DRAIN THE TRANSMISSION CASE, CLUTCH HOUSING, FINAL DRIVES, AND FRONT
AXLE COMPARTMENTS WHERE APPLICABLE. FLUSH TRANSMISSION WITH PROCE-
DURE OUTLINED IN THE TECHNICAL MANUAL UNDER HYDRAULIC REPAIR, USING
AN OIL TRANSFER PUMP. REMOVE THE TRANSMISSION PUMP INLET SCREEN TO
FACILITATE REMOVAL OF DEBRIS. DO NOT REUSE OIL DRAINED FROM COMPART-
MENTS. WHEN COMPARTMENTS ARE DRAINED, FLUSH AS SOON AS POSSIBLE AND
REFILL WITH CLEAN OIL. IF COMPARTMENTS ARE DRAINED AND LEFT EMPTY,
RUST AND CORROSION WILL FORM. AFTER FLUSHING, CIRCULATE HOT AIR
THROUGHOUT CASE IF POSSIBLE, TRY TO DRY ANY MOISTURE REMAINING ON
COMPONENTS.
4. REMOVE ANY DRAIN LINES TO THE TRANSMISSION SUMP TO SEE IF WATER IS
PRESENT (SUCH AS DRAIN FROM MAIN HYDRAULIC PUMP, SELECTIVE CONTROL
VALVES, ETC.). IF WATER IS PRESENT, THE COMPONENT SHOULD BE DIS-
ASSEMBLED AND THOROUGHLY CLEANED.
5. DRAIN AND FLUSH THE FUEL TANK. DRY COMPLETELY BEFORE REFILLING.
6. REPLACE ALL HYDRAULIC, FUEL AND AIR FILTERS. LUBE ALL GREASE ZERKS
SUFFICIENTLY TO FLUSH WATER AND DEBRIS. REPACK FRONT WHEEL BEARINGS
ON 2WD TRACTORS. IF APPLICABLE, INSTALL GREASE FITTINGS AND
LUBE TO FLUSH WATER AND DEBRIS FROM AXLE OUTER BEARINGS.
7. CLEAN EXTERNAL DEBRIS FROM RADIATOR, OIL COOLER, CONDENSOR, EXHAUST
SYSTEM, INTAKE SYSTEM AND FROM ALL EXTERNAL CONTROL LINKAGES, ETC.
8. FLUSH THE AIR CONDITIONER COMPRESSOR CLUTCH WITH CLEAN WATER.
9. ON MOST MODELS WITH SOUND GARD BODY, THE BLOWER MOTOR, RIGHT
RIGHT WIPER MOTOR AND AIR CONDITIONER TEMPERATURE CONTROL
WILL FILL WITH WATER WHEN SUBMERGED AND WILL PROBABLY EX-
PERIENCE EARLY FAILURE. THE LEFT HAND WIPER MOTOR IS SEALED AND
SHOULD BE OKAY.
10. CLEAN AND REPLACE FRESH AIR FILTER.
11. DRY THE RADIO, SPEAKERS AND SWITCHES/CONTROLS INSIDE THE CAB
WITH HOT AIR.
12. DISCONNECT ALL SEALED ELECTRICAL CONNECTIONS AND CLEAN AND DRY IF
WATER IS PRESENT.
13. REMOVE ALL ELECTRONIC CONTROL UNITS; CCU, HCU, ETC.
DISASSEMBLE UNITS AND CLEAN AND DRY IF WATER IS PRESENT.
DRY THE INTERNAL COMPONENTS WITH HOT AIR.
14. RINSE THE ALTERNATOR WITH CLEAN WATER. WHEN TRACTOR CAN BE STARTED,
OBSERVE THE VOLTMETER FOR CHARGE. IF CHARGE IF LOW, REMOVE SLIP
RINGS AND BRUSHES AND CLEAN. IF BATTERY LEVEL IS OVERFILLED, DRAIN
TO FULL LEVEL AND CHARGE AT LOW RATE. IF SPECIFICS GRAVITY IS LESS
THAN 1.25, DUMP THE BATTERY FLUID AND REFILL WITH DRY CHARGE FILL.
15. WHEN THE TRACTOR HAS BEEN REASSEMBLED AND CAN BE STARTED, FINISH THE
HYDRAULIC CLEANUP PROCEDURE AS OUTLINED IN THE TECHNICAL MANUAL.
RUN TRACTOR AT OPERATING TEMPERATURE FOR EXTENDED PERIOD TO EVAPOR-
ATE ANY REMAINING MOISTURE.
8010, 8020, 8430, 8440, 8450, 8560, 8570, 8630, 8640, 8650, 8760, 8770, 8850, 8870, 8960, 8970, 9100, 9200, 9300, 9400, 8100T, 8200T, 8300T, 8400T, 510, 710, 820, 830, 840, 920, 930, 940, 1010, 1020, 1030, 1040, 1120, 1130, 1140, 1250, 1350, 1450, 1520, 1530, 1550, 1630, 1640, 1650, 1750, 1830, 1850, 1950, 2010, 2020, 2030, 2040, 2120, 2130, 2140, 2150, 2155, 2240, 2250, 2255, 2350, 2355, 2440, 2450, 2510, 2520, 2550, 2555, 2630, 2640, 2650, 2750, 2755, 2840, 2850, 2855, 2940, 2950, 2955, 3010, 3020, 3030, 3040, 3050, 3055, 3130, 3140, 3150, 3155, 3255, 3350, 3640, 3650, 4000, 4010, 4020, 4030, 4040, 4050, 4055, 4230, 4240, 4250, 4255, 4320, 4430, 4440, 4450, 4455, 4520, 4555, 4560, 4620, 4630, 4640, 4650, 4755, 4760, 4840, 4850, 4955, 4960, 5010, 5020, 6030, 6100, 6110, 6200, 6210, 6300, 6310S, 6400, 6405, 6410, 6500, 6510S, 6600, 6605, 6800, 7020, 7200, 7210, 7400, 7405, 7410, 7520, 7600, 7610, 7700, 7710, 7800, 7810, 8100, 8200, 8300, 8400, 2040S, 2355N, 2855N, 4040L, 4040S, 4240L, 4240S, 6110L, 6200L, 6210L, 6300L, 6310L, 6400L, 6410L, 6500L, 6510L, 8110, 8210, 8310, 8410, 8110T, 8210T, 8310T, 8410T, 9300T, 9400T, 7510, 8120, 8120T, 8220, 8220T, 8320, 8320T, 8420, 8420T, 8520, 8520T, 6120, 6220, 6320, 6420, 7220, 7320, 7420
CAB, ELEC, ENG, FA, HYD, MISC, PT, SB, F0200, F0300, F0400, F0500, F0600, F0700, F0900, FF1300, F1600, F1700, F1800, F2000, F2100, CHECK, CLEANER, CORROSION, DEBRIS, FAIL, FLUID, OIL, RUST, SPRAY, WATER
John
11-09-2002 06:24:05
I cant seem to think of much more than the obvious fluid/filter change. I would probably run it for a continious hour first thing and do the fluid filter again. That would hopefully reduce the moisture in the oils which is more damaging longterm that actual water droplets.
John
11-09-2002 06:24:01
