JD 70 LP manifold on 70 gas
Jim V
11-15-2002 23:25:29
Will a 70 LP manifold bolt on in place of gas manifold and perform like the gas manifold or will there be some problems with the installation and performance? Thanks Jim
G Taylor
11-16-2002 20:21:36
 Re: JD 70 LP manifold on 70 gas in reply to Jim V, 11-15-2002 23:25:29
LP manifolds work fine for competive pulling for max HP. A parade, odd jobs tractor or one used in cool/cold weather should have a heated manifold and be turned on.
70JD
11-16-2002 19:52:05
It is a bolt on deal, may have to adj throttle leakage.
Clooney
11-16-2002 04:47:37
Jim, as far as I know it will bolt on. ~You will loose your heat valve & the linkage will probably have to be custom fit. Depending on the S/N I'm not sure if the intake elbow pipe will fit.
