3010 hydraulic hoses work, 3pt arms don't
Jerry S
11-19-2002 08:55:07
3010 is at it again. Not sure why the 3pt arms don't want to lift but the other hydraulic functions are ok. Have a shop manual for the tractor but not smart enough on these to figure it out. Anyone have this experience? THanks for your help.
DON
11-19-2002 14:55:32
 Re: 3010 hydraulic hoses work, 3pt arms don't in reply to Jerry S, 11-19-2002 08:55:07
REMOVE THE RIGHT HAND ROCKSHAFT COVER , YOU WILL SEE THE CABLE THAT OPERATES THE VALVE. MOST LIKELY ITS BROKE. DON
Dan S.
11-19-2002 12:39:50
check the linkage between the handle and the 3pt. also there is a "screw" of some sort inside the case that can be accessed through a plug in the rear of the case on the right side. i am not sure what this exactly does, or which way to adjust it, so I will leave it to someone else who knows.
F-I-T
11-19-2002 09:53:51
Jerry:
Been a long time since my days on the 4020, but once my Dad bumped the L-LD-D lever under the seat to a position in between settings and similar things happened.
Might want to check it.
Frank-in-Tallahassee
70D // 855
