J.D. 160 Tractor
Jerry W.
12-28-2003 12:18:37
I need help, I want to pull the tire off of my 160, I removed the snap ring, and now I can't get the tire to slide off of the axle. I tried prying from behind the tire and it still will not budge.
I don't see any other it would be fastened the the axle.
Does anyone have any suggestions?
Thank You,
Jerry
RAY
12-29-2003 06:23:51
 Re: J.D. 160 Tractor in reply to Jerry W., 12-28-2003 12:18:37
THE WHEEL SHOULD JUST SLIDE OFF, UNLESS THERE IS A DAMAGED BEARING OR A BURR ON THE AXEL. TRY PUTTING A BLOCK OF WOOD LIKE A 2X2 AGAINST THE INSIDE OF THE RIM AND HITTING IT. TAKE CARE TO ROTATE THE WHEEL TO CHANGE LOCATIONS OF IMPACT TO REDUCE THE CHANCE OF DAMAGE TO THE RIM.
