Flywheel- Model A/ Model 60?
jim unger
11-26-2002 08:45:24
Is the model A flywheel the same as the one used on the model 60?
thanks in advance, for your help.
Clooney
11-26-2002 10:14:33
 Re: flywheel- Model A/ Model 60? in reply to jim unger, 11-26-2002 08:45:24
Jim, the late [A] {mid 1947 } & up should be the same.....
Mike Aylward
11-26-2002 10:54:54
 Re: Re: flywheel- Model A/ Model 60? in reply to Clooney, 11-26-2002 10:14:33
Jim and Clooney, the flywheels are the same part number but not necessarily the same! The basic flywheels are identical looking but one from a 60 will be marked for timing marks. Get a 60 flywheel cover with the inspection hole and you will be able to do a better job of timing the old girl. Hope this helps. Mike
