Ground cable on 46'B
Joe
11-30-2002 18:25:27
my B has the starter on top of the crank case, where do you connnect the ground cable? does it go to one of the Starter bolts?
thanks
John T
12-01-2002 05:54:41
 Re: ground cable on 46'B in reply to Joe, 11-30-2002 18:25:27
Joe, although it may not be absolutely "Correct Police" correct, the closer to the starter you can attach it the better electrically speaking. The starter draws its current, of course, between the Pos and Neg Battery terminals, so thats why closer is better to minimize voltage drop across the cables or paths of conduction. A good sized bolt that attaches the starter or the mounting assembly upon which you clean and wire brush the bolt and threads and any metal to metal contact would be fine. I recommend a minimum of 00 Gauge on 6 volt systems and 0 on 12 volt on starter and ground cables. John T Nordhoff in Indiana
Sam Vastano
12-01-2002 04:47:49
Joe,
I have mine attached to a bolt that is on the pedistal that holds the dash.
Hope this helps
Sam
