1947 model A oiling
j staco
12-01-2002 05:31:25
does the governor oil line do anything other than supply oil to the guage?how does the bearing closest to the mag. and the rear fan bearing get oil? mine aren`t
Clooney
12-01-2002 05:52:26
 Re: 1947 model A oiling in reply to j staco, 12-01-2002 05:31:25
j staco, the governor oil line supplies a stream of oil to the governor that kind of squirts on the fan gear set & is then splashed & slung around to oil the governor bearings. The oil enters the mag end bearing from a hole in the casting that slung oil flows through.
~It has to run a while & at a good RPM before the oil actually gets to the bearings.
staco
12-01-2002 07:54:58
 Re: Re: 1947 model A oiling in reply to Clooney, 12-01-2002 05:52:26
the oil passage to the fan set must be blocked. I sprayed wd40 in and blocked off the oil pressure line and hooked an air line to the governor supply line. nothing comes through anywhere.how can clear this
Lee
12-01-2002 08:28:01
 Re: Re: Re: 1947 model A oiling in reply to staco, 12-01-2002 07:54:58
That oil passage is very small, it runs from oil pressure gauge line hole straight left to spray on larger fan drive gear on governor shaft. From there oil is slung to every thing else. Try a grease gun in that hole to get higher pressure? Then air again to move the grease out as that will stop oil too at least for an hour or two.
staco
12-01-2002 11:49:34
 Re: Re: Re: Re: 1947 model A oiling in reply to Lee, 12-01-2002 08:28:01
the grease gun worked perfect,I would never have found it otherwise. Thank You
Lee
12-02-2002 18:29:16
 Re: Re: Re: Re: Re: 1947 model A oiling in reply to staco, 12-01-2002 11:49:34
You're welcome. I'm glad it worked too, sure beats tearing it down just to clear that little hole.
Clooney
12-01-2002 08:09:55
staco, you will probably have to pull it apart & see where the blockage is.
