1020 Diesel w/Roosa Master injector pump
KB
12-01-2002 18:09:18
I do not have much experience with diesel engines so I don't know what to make of this, hope someone can help me. We have a 1020 with a Roosa Master injector pump on it on the top of the injector pump there are 2 plugs the rear most plug is leaking fuel. It is leaking to the point that if it sets in the same place idling for a few min. it will leave a small puddle on the ground. We have it parked until we know what we are dealing with here. Any ideas? My current assumption is that this is a bleader plug and that all we have to do is tighten it but again I am not a diesel guy and really would like to avoid messing up something that would probably be expensive to replace.
Thanks in advance for your help!
Al
12-01-2002 18:56:19
 Re: 1020 Diesel w/Roosa Master injector pump in reply to KB, 12-01-2002 18:09:18
If it doesn't have a cable lock on it try to tighten. If can't it may be the copper washer under the cap damaged.
