Draw bolt WORN LOOK!!!
Joe
12-03-2002 14:52:43
third party image
This is the bolt that takes all the load from my swinging drawbar. It was very loose, so i took the two main bolts out, VERY TIGHT, and this is what i found. Ive never seen a bolt this worn....
CJDave
12-04-2002 05:47:18
 Re: Draw bolt WORN LOOK!!! in reply to Joe, 12-03-2002 14:52:43
We used to pull IH Model 55W balers with our JD A's and that's what the WHOLE HITCH assembly looked like from that heavy engine-driven baler slamming back and forth constantly. We finally got smart and built special "baler hitches" that hooked to the axles. Our biggest trouble was having the bolts that threaded into the belly of the tractor loosen and wear out the threads. There's nothing quite like having the implement come loose and then destroy the hydraulics when the hoses stretched and broke the fittings or worse....
Frank M.
12-03-2002 19:19:49
You found that one in the nick of time. How much damage did you prevent by catching that before it broke?
Joe
12-04-2002 06:43:30
 Re: Re: Draw bolt WORN LOOK!!! in reply to Frank M., 12-03-2002 19:19:49
Well, i plow sometimes, but mostly i pull my 20' double axle trailer from the back yard to my house, i live on a hill, so if it broke, the trailer would go very fast down the hill and probably hit the truck parked down there! and sometimes down the road a bit. Im glad i spotted that this soon!
Joe
12-03-2002 16:57:56
Sorry, forgot to say its off A 46' B
steve II JD4000
12-03-2002 16:51:45
what was it off of..? be nice to know.
zippo
12-03-2002 15:23:28
damn
