2010 governer
john
12-04-2002 18:28:14
Hello, I am new to john deere just bought a 2010 gas and it seems like the governer doesn't work?
Was just curious if some one could expain how to check and adjust if neccesary any help would be much appreciated. Thanks John
Tom in Mo.
12-05-2002 17:36:01
 Re: 2010 governer in reply to john, 12-04-2002 18:28:14
Hello John, It seems like most of the guys don't like the 2010's because the first two years that they made them, Deere had many design faults built in. The biggest faults being the hydraulics and the diesel engine. The last couple of years they made them, the faults were fixed but it was too late for the reputation to be saved. My advice to you is if you want to keep the tractor and use it, get a factory service manual. The I and T manuals are good for many things but cannot compare to the factory service manual. The tractors made after serial number 42000 had most of the bugs worked out of 'em. Early models were a problem. I like my 2010. It is a 1965 model and has good power and is easy to handle. You should be able to tell if the governor is working by trying to move the linkage with your hand while idleing; it should resist your pulling on it. You may just need to lubricate or adjust the linkage.
