1945 g purchase
abe
12-08-2002 19:51:41
can buy a 45 g 15773 for 1500.00
needs tires/paint/good tin/hyd/
has water pmp/rollomatic/all fuel manifold/
good buy????? ????? ?
does run/
abe
12-10-2002 10:52:51
 Re: 1945 g purchase in reply to abe, 12-08-2002 19:51:41
the serial #15773 and does it run
has roll a matic and water pump
i will bring it home thanks abe
DP
12-08-2002 22:34:42
Duh!!!! Just didn't read. It does run.
DP
12-08-2002 22:23:14
Hi Abe; You didn't say if the G runs. It is actually a GM with that SN. The Rolla-Matic wasn't introduced till 1947, and the Water pump, if John Deere, wasn't factory till mid-way 1952. There are many earlier models that have had these added later. If the tractor is running, that sounds like a reasonal price. All G's came from the factory with the power fuel manifolds. Good luck to you if you buy it. They are a lot of fun to have. I've got four of them of different ages.
brian
12-09-2002 12:25:10
 Re: Re: 1945 g purchase in reply to DP , 12-08-2002 22:23:14
DP, the roll-o-matic came out in 1950 not 1947.
Will P
12-09-2002 15:48:28
 Re: Re: Re: 1945 g purchase in reply to brian, 12-09-2002 12:25:10
I have a 49G with rollomatic. The 2 piece pedestal came out in 1950, I'm pretty sure.
Will P
Stan - Florida
12-09-2002 14:08:40
Brian,
The A had Roll-o-Matic at S/N 584000 (the first late styled A) and the B had it at 201000 (the first late styled B). As early as May 1947 sales brochures pointed this out.
The G may have had it before 1950 as well, but I don't know that for sure. The two-piece pedestal became an option in 1950 for the G.
Stan
G-MAN
12-09-2002 15:33:26
 Re: Re: Re: Re: 1945 g purchase in reply to Stan - Florida, 12-09-2002 14:08:40
I think the rollomatic was available for the "G" at the same time it was available for the "A" and "B". I think when they made the changeover from the "GM" back to the "G" it became available. Since the pedestal itself was identical, it would have been very simply to order the rollamatic assembly from Deere as wholegoods and install it on a "GM".
