1949 JD A HOOD REMOVAL,NEED INFO PLEASE
FRED
12-11-2002 06:44:15
1949 A ,DOES THE GAS TANK COME OFF WITH THE HOOD,OR SEPERAT ? I KNOW THE STEERING SHAFT COMES OFF,GOT THE GRILLS OFF AND THE NOSE CONE OFF,NEED HELP WITH THE HOOD NOW,THANKS,FRED IN ARIZONA.
F-I-T
12-11-2002 07:02:21
 Re: 1949 JD A HOOD REMOVAL,NEED INFO PLEASE in reply to FRED, 12-11-2002 06:44:15
Fred:
The easiest way by far is to drain the tank and remove it with the hood. The most difficult part is lifting it all the way up and over the muffler and air intake.
Unless you have a need to have access to the tank, leave them mated.
Frank-in-Tallahassee
70D // 855
jason r
12-11-2002 06:56:02
fred, there are two clamps at the rear of the hood. they attach the tank/hood to the gov. if it is an all-fuel a you can get by with leaving the tank in the hood. that saves trouble later. if the a is a gas then you can loosen the two bolts in the front underside of the tank. this will loosen the hood from the tank and it should slide right off. when you go to put it back on it will be a pain to get on but take your time and use a bar for leverage to keep the tank from falling out of the hood. a second set of hands always comes in handy too
