1949 JD A,STEERING SHAFT REMOVAL,NEED INFO.
FRED
12-11-2002 08:01:45
I GOT THE HOOD AND THE TANK READY TO COME OFF,THERES A BIG NUT AT THE END OF THE SHAFT,DOES IT NEED TO COME OUT,OR THE PLATE ON THE FRONT OF THE GEAR BOX ?? NEED MORE INFO HELP,THANKS,FRED.
John T
12-11-2002 12:32:55
 Re: 1949 JD A,STEERING SHAFT REMOVAL,NEED INFO. in reply to FRED, 12-11-2002 08:01:45
Fred, after you get it out as Frank described and your ready to put it back, if it had excess end to end horizontal play, it may be time to remove some of the end cap shims and it may be time to adjust the half moon sector gear (under the pedestal top) back over closer to the shafts worm, but not too close in the middle where the most wear is, or it will then be too tight out on the ends. Good Luck, Ol John T Nordhoff
F-I-T
12-11-2002 08:09:37
Fred:
Remove the steering wheel. Remove the two cap screws holding bearing cap on the front of the pedestal. Don't lose any of the shims from the cap. Turn the steering shaft and it will screw itself forward and out. Pull the shaft out and clear.
There ya go.
Frank-in-Tallahassee
70D // 855
