#5 mower wooden grass board value
Eric
12-12-2002 18:39:00
I have a #5h and a #5. I plan to replace the knife, make 1 out of 2 and have parts for later. The "h" has no grass board and the other has a metal one. Can anybody date them for me and tell me how to know if a wooden board would attach or not. It looks as though it would not because of the hole patterns. The parts list I have is incomplete and shows only a wooden board.
Dave in Ohio
12-14-2002 05:09:05
 Re: #5 mower wooden grass board value in reply to Eric, 12-12-2002 18:39:00
The #5 mower came with a wooden grass board. Your John Deere dealer will sell you a replacement which is now metal for $55.00
ron in MN
12-13-2002 15:16:36
Eric, I have two #5 mowers and as Dan said I haven't heard of a 5H. Could you explain that one for us? My parts book is complete and only shows a wood grass board and makes no mention of a metal grass board. Dan is probably right in that a metal board is either homemade or a none-Deere product.
Eric
12-13-2002 19:37:00
 Re: Re: #5 mower wooden grass board value in reply to ron in MN, 12-13-2002 15:16:36
Hey guys, thanx for the responses. I guess I assumed that a #5 w/ a hydraulic lift would be a #5h. Sorry for any confusion. I admit my special "greeness" (not to be confused with JD Green). Now a novice, not always to be though.
Dan
12-12-2002 20:50:36
I am not sure what the #5 H is. Is that one with hydraulic lift? I have and have had severl #5 mowers, I didn't think there was any difference in the way the grass board bolts on. On both my #5 and #8 it has one hole and bolts to the outer shoe. There is a heavy spring on the bolt to keep it from flopping around but allow it to move some. I had a regular all wood grass board on it to start with. Had a metal piece to keep the bottom from wearing and a metal piece where bolt went through to attach to mower. Still have it but have reinforces it some as I use the mower and over time the old one gave out. I have seen them with metal grass boards but not really sure the metal ones were made by deere.
